wobblycogs
A few weeks ago I posted a question asking about a modification I was considering making to my PT. At the end of that thread I decided to replace the chain and see if that fixed the issue. Many thanks for all your help there but now I come to actually do the job I don't think the chain is the issue. I debated just tacking this question on the end of that thread but it's a different issue so I thought it warranted it's own discussion.
I bought a chain tool and a new chain (as close a match as I could find) and set about the repair. The chain came apart easily but when I came to inspect the sprocket on the outfeed roller for damage I discovered it was nearly impossible to rotate by hand
. This machine has failed similarly to this before. According to Jet it was due to overly hard bushing material and they even had a free onsite repair (that's long since ended). I replaced the bushings a couple of years ago and everything had been running fine.
When I got the replacement bushings they came pre-greased and I seem to remember reading they didn't need anything else, this seems to be wrong though and I can't find where I read that. The bushings have no oiling points built in but they pretty clearly need some lubrication. I'm convinced now that the chain is slipping on the outfeed roller because it requires excessive force to rotate. If I put a spanner on the locking nut I can rotate the shaft so it's not completely seized. It's smooth running but tight, it feels like dried up old grease is the issue.
I think I need to fit lubrication points to these bushings but this is outside my experience so I could do with some advice. At the moment I have two ideas for where to add lubrication points (please see photos attached).
Idea 1... Three of the four bushings are fairly easy to access and the fourth is do-able. I could probably add a grease fitting to the side of the bushing. The problem is the bushing wall is quite thin where I'd need to add the fitting. It's thin enough I'd probably need to remove the lead in on the thread of the nipple. I'm concerned something will fail over time.
Idea 2... On top of the bushings is a spring and grub screw to apply downward pressure on the timber. There's a flat spot on the bushing for the spring to seat on. There's not space for a grease fitting but I could drill through the bushing at this point. To lubricate the bushing I'd remove the grub screw and inject a little oil. This area isn't sealed off so oil will run out but some will make it in, the hole through the bushing will act as a tiny reservoir.
I'm favouring option 2, it's simple and I'm pretty confident it'll work. Any advice welcome.
As for what to use for lubrication, I have oil for the headstock of my wood lathe that feels like it would be perfect, just the right viscosity. I honestly have no idea what's best though.
Many thanks for any help.
