Question for all of you who own and/or know how to use a Dominion Elliot Minor (I guess that's primarily @SammyQ ...?)
I have one of those that's been in the corner of my workshop for a while. I've been trying to understand how to make use of it correctly, safely and accurately. The original manual (provided by @SammyQ in a previous thread) is just about useless for that.
I have therefore a few questions I'm hoping someone will kindly help with...
1. There are 2 blots on the vertical central shaft (as per this photo).
The bottom one is clearly used to lock the "boom" at certain angles. It's a little fiddly but seems to work. The top one on the other hand, which can't be turned more than about 120 degrees from vertical (because of the bottom one being in the way) doesn't seem to do much. What is it for?
2. The base of the vertical shaft also has a tightening bolt, which prevents rotation of the main part of the machine. There are also regular holes in that plate, and a metal stick (right on the photo) that seems to fit in some of those holes, but I am uncertain what it's supposed to be used for...
3. Event with those various locks, I'm finding it very difficult to accurately set the boom for the radial arm saw at 90 degrees to the table. Each time I'm having to use a large carpenter square, and raise the table so that I can move the blade back and forth alongside it to try and get them parallel. There must be a simpler way... Any advice?
4. Same goes with mitering (45 deg angles). When I set the arm at 45 deg, it's almost at the end of the table. Is that really meant to be how it's done?
5. There's a metal bar at the end of the table saw table. With a thumb wheel on it. No clue what it is for...
6. It seems really difficult to remove the belt going from the motor to the arm saw. When I use the planer, I add the longer belt between the motor and the planer wheel. But obviously when it's turned on, the saw will also rotate, which seems a massively dangerous thing to do (as it's partly invisible under the guard, on the other side of the machine). Should I remove that small belt, or the blade itself, every time?
That's all I can think of for now.
Any advice on any of those points would be massively welcome!
Cheers,
Wabiloo
![IMG_0391 Medium.jpeg IMG_0391 Medium.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/129/129488-IMG-0391-Medium.jpeg)
![IMG_0392 Medium.jpeg IMG_0392 Medium.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/129/129489-IMG-0392-Medium.jpeg)
![IMG_0393 Medium.jpeg IMG_0393 Medium.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/129/129491-IMG-0393-Medium.jpeg)
![IMG_0394 Medium.jpeg IMG_0394 Medium.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/129/129490-IMG-0394-Medium.jpeg)
Cheers,
Wabiloo
