Ferrules
Rhyolith
15 Dec 2015
Darlington
I have been very casually dabbling in making walking sticks and now my "client" wants them to have ferrules. I am assuming there is a method for fitting them?
Also where do you get them from?
Hi - my preferred material is a short piece of copper or brass tube, cut to length with a hacksaw, and secured with a copper nail. I just use a sharp whittling blade to shave the end of the stick to receive the ferrule - it doesn't need to be perfect. Cheers, W2S
Taper the end of the stick and revolve the ferrule on the end to leave witness.
The ferules are normally dirty inside which aids the process.
Run a sharp knike around the stick to create a shoulder for the ferrule to register against.
You can use epoxy or pin the ferrule.
There may be a guide to fitting on the stickman website.
If the application means the ferrule can be forced on the tenon doesn't need to be perfect so it's usually just a whittle or paring job for me. For a very nice fit I leave the tenon large, then fine-tune with a file. Although if you're good with a knife or chisel they are all you need I find you can sneak up on a perfect fit faster and more easily by filing. Also a godsend where the grain is being a pain.
If you do go too far and end up with a rattling fit (not that I'm speaking from personal experience, no sir) you can glue a shaving around the wood to pack it out, or glue the ferrule in place with a firm mix of epoxy and sanding dust.
