In the last few years I've done quite a bit of research to the effects of chipbreakers. For me the first objective was that every plane I have, posesses a chipbreaker and I didn't really know how to use it. I did see some effect but wasn't immediately impressed. Back then I used backbevels and also a ROS quite often. Even with simple stuff like Ash or sof Maple. High angle planes weren't in my repertoire because they are quite inavailable on the antique market. The Kato video really opened my eyes to see how close the capiron should really be to the edge.
This very close setting does several things. It allows to forget about a tight mouth. In a Baley plane you get the best support when the frog is pulled back. It also support the edge right where you need it, just behind the edge. And of course it works just as well to prevent tearout as a high cutting angle up to 60-65 degrees or so. Above that you start to scrape. A very nice thing is its adjustability. So in somewhat less demanding woodyou can pull it back a bit to get a smoother surface with less force. That's about smoothers. In jack planes the capiron can't be set quite as close but it is still effective at a larger distance with thick shavings not entirelly avoiding tearout but certainly helping to reduce the depth and serousness of the tearout. Single iron jack planes can really tear up the wood.
Overall I am pretty happy how it works in my simple Stanleys and woodies. You do need to prepare the capiron carefully (once). Like I wrote before, for really rotten stuff like some curly interlocked Meranti I had a while ago, I have an Ulmia york pitch plane with capiron.
