Guys, I have enjoyed DC's video ''Furniture-Making Techniques'' a lot. There is one thing
I don't understand.
For really though wood, DC sharpens his plane blade with a 25 degree back bevel. This part I understand. DC
uses a slight camber on his blades, using pressure at the sides to create it. So far easy to understand.
Then DC removes the wire edge(hones the back bevel), but uses only centre pressure. That seems odd to me.
The middle of the blade(both on the beveled and the flat/back side) is touching the waterstones first. So
by using only centre pressure, more of the middle is removed than on the sides, since the middle is
touching first and only by abrading the middle can one start honing the sides. I think DC is changing
the geometry of the blade this way. What do you guys think?
When there is no back bevel, the flat face is touching the stone evenly and there is no problem, but with
a back bevel the middle of the edge is touching the stone first and the edges last. This issue might not be
a problem with a tiny back bevel that is removed with the ruler trick. However the steeper the angle of the
backbevel, the more it becomes a problem(if my thinking is correct).
Have I got it wrong?
Ali
I don't understand.
Ali
