CStanford":3m7pbcie said:
Thin quartersawn material for sides whenever possible.
It's not necessarily always a good match Charles, assuming there's a plan to mix this choice with tangentially sawn drawer fronts, although I realise you mentioned 1/4 sawn drawer fronts in your post. It's a good match when radially sawn European oak drawer sides are paired with tangentially sawn American mahogany fronts: the shrinkage factor of the radially sawn oak is very close to the shrinkage factor for American mahogany, i.e., both very slightly over 5% as they dry from green to 0% MC.
Switching the choice around wouldn't be ideal I'd say, and mahogany was often used for drawer sides in the past, i.e., 1/4 sawn mahogany sides with tangentially sawn European oak, where shrinkage factors are typically 3.7% for the former, and 8.9% for the latter.
However, having said all that I suggest the latter choice might only become a problem if the drawer is especially deep top to bottom, e.g., 250 mm (10") or more, and such depth, although somewhat rare is not unheard of.
As to the general topic of fitting drawers to openings, the so called 'piston fit' drawer I suggest really only has applications in smaller drawers, the sort of things you might find in jewellery cabinets or internal compartments of desks, and the like. For general carcasses such as chests of drawers and so on there's no point making them a really tight fit in the opening for all the reasons already mentioned in this thread - who wants drawers jammed solid in the summer and only usable in the winter and spring (here in the UK in most residences)? Slainte.
