OPJ
hpl":3fqxp2u5 said:The reason I mention the floor standing one is that the timber I am sanding is up to 50mm thick, the 19mm bobbin doesn't extend that high when it is in the lowest part of the stroke, making it a bit awkward to use. I would then have to find floor space for it though!
Johnny, you won't have that trouble with the benchtop Jet model - that's one of the reasons why Ray has made his sub-table, so the top of the bobbin actually does some work! :wink:
If you can't get your money back then Charnwood should be able to 'fix' any issues you have with your machine. It should be covered by a two-year warranty. You should at least be able to get it in to a condition where it's fit enough to be sold on.
