Hi,
it would help if I knew how to ask the question properly so bear with me please! Just got a Naerok GP 13 bench drill that runs through a MTE Sprite inverter / controller, my question is basically am I better to leave that on its top setting and still change speeds with the belt or adjust speed with the controller?
In use it will be mainly timber to begin with but there will be metal work going on, not fussed about changing the belt when I need too more bothered about the inverter and how long that makes things last. I don't understand how they work exactly so does it stress the motor on the drill using a inverter on low settings?
Have read you can lose some of the torque compared to running 3phase but I will not be drilling lumps of plate steel more waste when M&T and forstner bit use, but if running inverter to the max and changing speeds with the belt helps with that then all good.
The drill itself, pics from advert are below I haven't got my camera out yet, ex school had very little use so whilst it looks a bit shabby everything seems very good, got some good test holes, brooke compton motor sounds very smooth, it's all tight and working basically belt in good nick. Paid £40 for it so bit in the budget to tart it up if it's worth it? Was going to get rid of the rust and stick a new cable on it and sort a fancy table for it but apart from that if there is anything you would check / do I would be very grateful to hear any advice.
Thanks,
Dean
Thanks,
Dean
