20mm diamater transfer punch? Where to buy?
Prizen
19 Feb 2013
Dublin
Hi all
I wish to accurately replicate a workbench top (mdf) which has a series of 20mm holes drilled. I have figured that the most accurate way would be to clamp the new blank top underneath and a 20mm diameter transfer punch to locate the centre of the hole on the new top. Once complete I would route out the holes using a suitable 20mm cutter.
However, I cannot find where I can purchase a 20mm punch.
Any ideas?
MikeG.
24 Aug 2008
Essex/ Suffolk border
If you have a 20mm Forstner bit, just place that in the hole and either turn it by hand, or give it a little tap with a hammer, and it will leave a mark at the centre point.
porker
15 Oct 2009
Butlers Cross, Buckinghamshire
Hi,
Chronos do a 5-20mm transfer punch but looking at it I don't know how accurate it would be as it looks like a cone that I would think would have a degree of error in how perpendicular it was held. If you are using a 20mm cutter you would need to use one with a centre point (which most router cutters don't have). If you do have a cutter could you use the cutter itself as the transfer punch?
I'm dubious how accurate this method will be though. I used a template from cncdesign which uses a standard 1/2" router cutter and standard guide bush. It is made so an MFT top can be replicated including the fixing holes.
Matt
AES
18 Feb 2011
Switzerland, near Basel
Arc Eurotrade (link in the sticky at the top of this section) do a set of transfer punches, IF I remember correctly, actually 2 sets, one metric one imperial. usual disclaimers.
HTH
Eric The Viking
19 Jan 2010
I have a set, one conical and one stepped. Neither goes out to 20mm, and the pointed pins are a sloppy fit in the middle, anyway, so you cannot rely on them for accuracy.
The Forstner bit thing would be by far the easiest, but if this is some sort of MFT, it probably won't be accurate enough if there is any wear in the holes of the original piece..
AES
18 Feb 2011
The other thing you could do is make your own.
Find a bit of steel or ali bar which is a snug fit in the existing hole and "turn" a centre point on one end. A lathe is of course ideal for that, but if you don't have one available you can easily make your own which should be OK unless you want absolute accuracy (in which case a transfer punch is probably not the way to go - though I must say, my own set is accurate to about +/- 1 mm or a bit less, which IMO is fine for a lot of stuff).
To make your own just attack one end of the bar with a file to get it more or less conical by eye. Then chuck it in a drill and hold the point against a belt or disc sander, if necessary first marking a 45 degree line on the sander table with a soft pencil. Run the pointed rod in the drill SLOWLY, holding the point against the spinning disc/belt, adjusting your hold of the drill until the angle is just right. You don't need a really sharp point, just enough to make a clear mark on the job to be drilled.
As said, NOT the most accurate, but "good enough" for a lot of purposes. What's the job BTW?
marcros
11 Feb 2011
Leeds
a word of warning- if you buy a cheap set (mine are Silverline!), they may be listed as metric but they are not, they are imperial. I have never measured the accuracy, because I use them for squaring off pen blanks on a jig, so just get the closest fit.
toolsntat
Yep, I collect tools and tat
8 Dec 2007
Leicestershire England
You have the existing and the holes are good.
Can you not use a top guided plunge cut router cutter and your existing top?
Cheers Andy
chaoticbob
14 Nov 2012
Wirksworth
Arc Euro Trade do universal transfer punches . They are based on the 'punch in a cone' idea, but have a sliding collar on the outside of the cone which ensures that the punch is held perpendicular to the work. The larger size goes up to 26mm
Robin
MikeG.
24 Aug 2008
You're not following. Andy is suggesting using a following cutter........a cutter with a ball-bearing guide, and running that around the inside of the existing hole to create a replica in the sheet below. It wouldn't matter what size the cutter was (so long as it was smaller than 20mm).
toolsntat
8 Dec 2007
Sorry, just realised I am repeating, in a way, what was already suggested.
post1275492.html#p1275492
Setch":34of46vn said:
I'd fit a 20mm guide Bush to my router, and choose a suitable half inch cutter which can be plunged without clogging.
Plunge a half inch hole in each location, then swap the cutter for something larger - maybe a 16mm and repeat.
Fit a bearing guided cutter and set the depth so you cut 3mm of so into your new sheet, and slowly, carefully duplicate the full-size whole into the new sheet, being extra careful not to damage the CNC master.
Once you've got a full sized matrix 3mm deep, remove the master and repeat until your hopes are full depth.
PS: In my experience forstners clog hopelessly in MDF, but mine are pretty cheap and nasty.
OscarG
3 Jun 2016
London
HTH
I have the metric set, been pretty happy with them, but only goes up to 13mm though.
Levitric
7 Jul 2021
Cambs
Hi all
Any ideas?
Did you ever get this resolved, I too have come to the same conclusion as ylurself so am interested in how you got on.
profchris
14 Jun 2015
Suffolk
A 20mm auger bit is under £10 from Screwfix and Toolstation. Accurate enough to use as a centre punch? Or even go mad, put it in a brace and drill the first few mm of the holes to use as a guide for later routing. Or even madder, go all the way with the hand brace! (NOTE: I have no idea what precision is needed, an auger might be too sloppy for this work I suppose).
