R Robbiedog New member Joined 22 Jun 2018 Messages 3 Reaction score 0 Location Cheshire 22 Jun 2018 #1 Hi, we've just acquired a Scheppach Bandsaw and we can't figure out how to turn it on. Any help would be greatly appreciated. Thanks
Phil Pascoe Established Member UKW Supporter Joined 29 Jan 2012 Messages 27,414 Reaction score 6,798 Location Shaft City, Mid Cornish Desert 22 Jun 2018 #2 Lift the red button, the switch is underneath.
J JonnyW Established Member Joined 19 Jun 2015 Messages 444 Reaction score 1 Location Lerwick 22 Jun 2018 #3 As per previous comment. Lift the red plastic emergency stop switch cover and the green for go button will be underneath it. Remember, put the red switch cover back down. It's there for easy access should you cut your arm off. Jonny
R Robbiedog New member Joined 22 Jun 2018 Messages 3 Reaction score 0 Location Cheshire 24 Jun 2018 #4 We've already tried that. We've tried the electrical connections and there fine. We're stumped
M mock Established Member Joined 25 Jun 2014 Messages 1,468 Reaction score 11 Location WALES, Nr Neath 24 Jun 2018 #5 are there any safety switches on the doors that could be dirty ?
Phil Pascoe Established Member UKW Supporter Joined 29 Jan 2012 Messages 27,414 Reaction score 6,798 Location Shaft City, Mid Cornish Desert 24 Jun 2018 #6 Or a door not quite shut?
B Bodgers Established Member Joined 21 Dec 2014 Messages 1,880 Reaction score 21 Location North Yorks 26 Jun 2018 #7 After having checked all the obvious stuff like fuses, safety switches etc. another to check which can fail is the starter capicitor. Sent from my Redmi Note 5 using Tapatalk
R Robbiedog New member Joined 22 Jun 2018 Messages 3 Reaction score 0 Location Cheshire 2 Jul 2018 #8 Ok will check that thanks, we've actually got 2 of them and can't get either of them to work .....
D delboy47 Established Member Joined 22 May 2014 Messages 89 Reaction score 2 Location Pontypool 9 Jul 2018 #9 Any progress on this? I have the same bandsaw and although I dont have any problems with it (fingers crossed) it would be interesting to know the outcome.
