Would it handle it?
caveman
20 Oct 2017
Devon
Stupid question?
I have an old Silverline planer and am wondering if the blades would cope with some soft aluminium.
I do not have a mill of any sort and I have to remove about 2 - 3mm from the 12mm wide face of a piece of 6mm X 12mm flat bar and was thinking that going fractions of a mm at a time it might just do the job. I would obviously mount the bar in a wooden holder for the operation, not try to push it across as is!!
Or am I daft to even contemplate it?
https://www.amazon.co.uk/Silverline-427715-Hi-Spec-Planer-Version/dp/B001C84DGQ
Well, I wouldn't. It might work but could go nastily wrong, and I don't think the surface would be very good.
How much do you have to do? why not just buys me 9 x 3 mm strip?
Keith
Probably will just buy another strip the right size, just a thought though!
Buy another strip, the sheer size of the cutting area would likely either stall the planer or launch it or the workpiece off at a terrifying rate. Terrible surface finish too.
You'd have much better results with a belt sander..........but of course, you'll never control the accuracy of the resulting surface.
Yes, I'd thought of that and I do have a belt sander. Accuracy isn't vital, ±0.00000001mm will do :lol:
