Phil Pascoe
There is a fair bit of interest in stoves at the moment, as the weather gets colder and fuel prices go up yet again, so I thought I'd start another thread as my questions are slightly different and I don't want to divert someone else's thread. I'm looking to move house soon - we'll rent for a short while, then sit like vultures and wait for the bargain or I might build if a decent plot comes along - so I might be buying another stove. At present I have a Clearview which is now in the region of £1400, which is a great stove but if I'm paying that sort of money I've loads of choice. I've been looking at Dowlings, which appeal to me because I wouldn't be replacing the insides perennially which I now know would influence my choice - my Clearview was £920 ten years ago, but has cost me about £500 in parts so far. Has anyone got experience of welded stoves? I was led to believe that cast iron was the best, but the more I think about it welded ones have their appeal - surely it is a little illogical to line a stove with fire bricks, as the heat can only go through the door, the top or up the chimney - it can't go through the sides or the back, you are effectively insulating the body of the stove from the heat within it (I know why it has to be insulated - the cast iron would probably crack). Welded ones would be better for a quick blast of heat , such as needed on a chilly autumn or spring evening, and I suppose in a workshop when you're not going to be there for hours. Has anyone experience of uninsulated stoves? Has anyone experience of backboilers? Any nightmares? Any dreams? Anything to look into? Anything to avoid? If I end up building, which would be brilliant, I need to make my mind up at the beginning as other things need to be designed around it. (Swmbo doesn't know this yet!) Even in a workshop I would avoid a cheap Chinese pot belly - they are garbage.
