wiring up a motor for a lathe/drum sander
marknotts
13 Mar 2015
nottingham
Sorry if this is the wrong forum but its for wiring up an induction motor so it could be for any tool, myself im building a combined wood lathe and drum sander
I opened the top to a 2hp single phase 4 pole induction motor to wire it up and didnt see the L N E i was expecting to see ;D , i'm hoping someone will be able to tell me which terminals to connect the live neutral and earth to please, it also appears to have 2 capacitors
Thanks and have a good friday I'm off to bed after a long shift and a 14h shift tonight :/
Thanks flh, i dont remember seeing a diagram in the lid but ill have a look when i get back home tomorrow morning, the wire im going to use is 2.5mm 3core flex which is effectively a recycled 5 gang extension lead that has a smashed socket box, the box will be chopped off and thrown leaving me with the flex plug and the 13amp fuse ;)
Sorry flh for the big delay but yes there was a diagram inside the lid which i saw after wiring up how you mentioned ;) and yep it worked so thanks buddy.
