Which tool?
knappers
19 Apr 2010
Leicester
Having been given a set of O'Donnell jaws for Xmas, what is the best tool for making the angled recesses or spigots to use them with?
I only have a basic axminster set of chisels so far. I would have thought trying to use the pointy end of the skew would just give me dig ins, yes?
Thanks guys.
Si.
paulm
IG paulm_outdoors
25 Sep 2005
North Hampshire
Pointy end of the skew Si, just use it slightly trailing like a scraper ie handle up, if worried about dig ins.
Cheers, Paul
boysie39
6 Sep 2007
carlow Ireland
mark out Dia. of recess with pencil ,tool rest across face of workpiece and use the parting tool.
Work into dept reqd. and take out that dept working to center
CHJ
31 Dec 2004
Cotswolds UK
1/2" skew, front angle to match jaw (15deg.?) lay flat (horizontally) on tool rest.
Likewise for spigot, only using 90deg. approach.
Jonzjob
19 Mar 2007
Ex nr Carcassonne, France. Now Corston Malmesbury
+ another 1.
If you are doing a tenon just remember to true the end of the blank or when you have cut the dovetail to go into the jaws there's a good chance that it won't sit square :oops: :oops: It may look square to the eye, but just true it up with your parting tool until you have a cut mark on the complete face!!
I only made that mistake once, then agin a couple of times more when I weren't thinking :oops: :oops:
OldWood
1 Mar 2005
Edinburgh
I've never thought of using the small skew for this as I use a 6mm parting/beading tool that has been ground to 15/20 degs. across of the face. I would reckon this is better in that being a parting tool it is shaped to do the facing for the tenon better and for the dovetail it is so much narrow a cutting face than the 12mm skew that is is far less likely to dig in. You can also twist it a bit to get in to clean up corners without there being 12mm of steel that is likely to catch somewhere.
Rob
