All 3 in as new condition
I will use 1st class recorded delivery and will charge, at cost, for delivery method
- £200.00 Axminster SK100 Clubman packaged set price new is £259.98 :-
- Thread 3/4" 16 tpi
- C dovetail jaws
- Faceplate ring
- Screw chuck
- Soft grip chuck key
- Long accessory mounting jaws
- £150 Axminster Woodturning O'Donnell Dovetail Jaws 3-in-1 Set, price new £199.98
- Made from stainless steel to protect against corrosion
- An extremely versatile set of jaws
- Enables better access to the workpiece
- Includes 50mm, 38mm and 25mm jaws
- Fits all Axminster 100mm and 114mm chucks
- Axminster SK100 O'Donnell Jaws - 50mm
- Designed for close-in tool work
- Deep recess holds long spigots
- Dovetailed inside and outside on lip
- 50mm Jaws threaded to accept optional jaw inserts
- Axminster O'Donnell Jaw inserts - 38mm & 25mm
- Parallel central bore for gripping a dowel
- Dovetailed section grips onto a spigot or expands into a recess
- Enables better access to the workpiece when turning bowls
- £75 Axminster SK100 Expanding Pin Chuck jaws - price new £109.98
Or £400 for all three...
- C dovetail jaws
- Faceplate ring
- Screw chuck
16 Axminster Woodturning ODonnell Dovetail Jaws 3-in-1 Set.jpg120.9 KB · Views: 0
18 Axminster Woodturning O'Donnell Dovetail Jaws 50mm.jpg178.7 KB · Views: 0
