I've read Scrit's post three times now (not a pleasant experience, but hey, I suffer willingly in the cause of truth 'n' justice :wink: ) and he doesn't say anything about the Lamello at all. :?JPEC":3k3blcni said:I agree with scrit, for precision and accurracy I don,t think you can beat the Lamello.
allan w":22tmx7ji said:mine is not cutting parallel to the side of the machine.
I have striped it down and there is no visible wear and the thing is still cutting half a mill out of parallel on a no 20 biscuit.
You cheeky so and so! :wink: I've looked longingly at the Lamellos for some 20 odd years now and I still conclude that they are extremely expensive and therefore I simply can't justify the cost. Yes, they're nice, but...... That's why I bought the old Elu DS140 (DW685) back in the year dot (around 1980) - they were about the only alternative to the Lamello then and the swing blade design probably comes from a bit of patent dodging. Mine still cuts square, so I'd also ask the question, "what state is your blade in?"Alf":hog3li3y said:I've read Scrit's post three times now (not a pleasant experience, but hey, I suffer willingly in the cause of truth 'n' justice :wink: ) and he doesn't say anything about the Lamello at all. :?JPEC":hog3li3y said:I agree with Scrit, for precision and accurracy I don't think you can beat the Lamello.
Scrit":2ctfx2hg said:(incidentally the DS140 is the only other biscuit jointer to have this facility and was there nearly 20 years before Lamello introduced the feature).
Scrit,
Bosch swing blade (sorry, don't know the number) - a bit lightweight in comparison to the DS140. I didn't think it would stay the course
I meant the swing type - the GUF 4-22A. If you notice the quadrant on those it is stamped steel. In my experience stamped stuff never seems as durable as alloy castings and is generally not as accurate (certainly the case if you look at circular saws). As by that time a long-time user of the DS140 (which has a cast alloy base) I felt I was in a good position to compare.Mike.C":puowl092 said:Do you mean the Bosch GFF 22A? http://www.axminster.co.uk/recno/1/prod ... -22178.htm or the Bosch GUF 22A?
http://cgi.ebay.co.uk/BOSCH-GUF-4-22A-B ... dZViewItem
