Vic Perrin
Hi, My second hand Tormek will soon be in need of a wheel replacement. I had a look at it yesterday and removed the nut that secures the wheel onto the shaft, fully expecting the wheel to slip off the shaft. However, it seems pretty well fixed to the shaft. I did not try any force whatsoever to try and remove it as there is still some life in the wheel and I was scared of damaging it.
Has anyone encountered this problem?
Also I believe that there are a number of replacements that can be used, at present the wheel in use is a well worn 250 SSG.
Regards
Vic
Regards
Vic
