Tormek corrosion inhibitor
AndrewS
4 Aug 2020
Banchory
Hello all,
I’m new to wet grinding and am interested to know if corrosion inhibitor is worthwhile with a standard stone and, if so, is it daft to consider using vehicle antifreeze (ethylene glycol) in lieu of the much more costly Tormek alternative?
Many thanks.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Where are you trying to inhibit from corroding? the only part on mine that gets a bit of corrosion is the main shaft which is trivial to remove and grease every now and then which will keep the water out.
Lons
14 Feb 2010
Northumberland
I don't bother and if it's one of the later Tormek models it should have a stainless steel shaft.
AndrewS
4 Aug 2020
Banchory
It’s a T8 so yes, stainless spindle. I was more thinking about the tool being sharpened - probably over thinking it in fact... I would always dry the tool thoroughly and wax/oil it so perhaps no need for corrosion inhibitor?
no idea
24 May 2014
London
The Tormek corrosion inhibitor is only needed if you are using their diamond wheels - the inhibitor is to protect the diamond coating, not the tool. As you say, you will, at the very least, dry your tools after sharpening so won't have an issue with corrosion on them due to the Tormek. Corrosion from damp or cold in your workshop is a separate matter.
