neilricketts
- Joined
- 21 Mar 2007
- Messages
- 89
- Reaction score
- 0
Hiya, i have just recently done some veneering with this glue and i thought i would share my opinion on this glue.
The task was to veneer some real wood oak and walnut veneer to some 18mm mdf. I have used a vacuum press for the clamping of the panels.
The glue itself is a light chocolately brown in colour and is reasonably thick. The instructions on the bottle say to clamp for 45mins to 2 hours depending on conditions. I used a 4" rubber stamp roller to apply an even coat of glue to the mdf and placed a piece of oak veneer to it. I then turned it over and did the same to the other side. Placed it in the bag and clamped it for 1 hour. When it was removed there was no evidence of bleed through which i was extremely happy with. However the following day when i checked the panel the veneer had bubbled on one side.
So with the second and third panel i followed the same procedure but left the panel in the press for 2 hours. Once removed still no evidence of bleed through and no bubbles. The following day checked the panels again and still no bubbles this time.
Same procedure again with the walnut veneer no bleed through and after 2 hours clamp time no bubbles. I have also used it to veneer the edge of the mdf and used normal clamps and cauls with no problems at all.
The glue does darked has it dries not lighter like normal glue but so far i am extremely happy with it.
Any comments are always welcome
Cheers Neil
Cheers Neil
