kenboy-01":2mm3fkoi said:…... I acquired 3/4 x 2mm nuts but the thread on these are to fine for the headstock spindle .....
2mm pitch would be 12.7 tpi ??? and as CHJ has pointed out 3/4" is 19.05mm so whatever you've acquired, you have either mis-measured or is a 'turnip' size.kenboy-01":2x2o7rnr said:... just out of curiosity I acquired 3/4 x 2mm nuts but the thread on these are too fine for the headstock spindle ... any ideas on this
I know where I stored it Ken but hadn't thought about selling tbh. Mine is a high quality tap probably much better than needed for the application where a cheapo will do the job. Will have a think though and let you know.kenboy-01":z871esw0 said:Hi if you can find this tap I will pay you plus post and packaging?
Ken
Cheapest seem to be in the link that J-G- posted. Use the drop down boxes for sizes & quantities.kenboy-01":25qmjzre said:Hi are you able to point me in the right direction on sourcing the above threaded nuts, I know the Headstock spindle thread is 20mmx2mm . I need these to mount various blank holding project.Regards Ken
kenboy-01":2druw2ur said:Bingo. I have just discovered, totally by chance that the threaded nuts from 22mm compression fittings marry up with the Head stock spindle. what happened was I needed to sought out my plumbing bits and pieces and noticed a few 22mm compression fittings and thought, "Hmm, and there you have it, perhaps this info may be of use to other members.
kenboy-01":15rqzh2d said:Bingo. I have just discovered, totally by chance that the threaded nuts from 22mm compression fittings marry up with the Head stock spindle.
