These "bar hinges"?
GrahamRounce
26 Jul 2007
Bethnal Green
Hi again,
I'm wondering if a pair like the ½hinge in the pic exists?
If my glorious artwork is intelligible, there are supposed to be 2 of them, so that a rod or bar goes through for a hinge effect.
What exactly do you want to use them for? What would they be attached to?
Ok, from the side:
The bits on either side are aluminium plates about 1cm thick (and 30cm square) that I want to swivel in a manner similar to those toy snakes you used to see, up to 45° either way.
I put some effort into fabricating them before thinking that perhaps they, or something that would give the same effect, exist already, which as I will want a couple of dozen would save me a lot of work!
Thanks,
Ok, from the side:
Thanks,
What about screw eyes/bolts? screw eye bolts - Google Search
