Taper Jig
Corset
5 Mar 2005
Nottingham
I am making a table/vanity table in oak at evening class among a few other projects at home and i have hit a problem.
My leg sections are 7.5cm square and when cut on the table saw ground it to a halt so i think i will have to use the large bandsaw. Anyway i want to keep the the first 15cm square and the rest of the leg tapered on four sides (though i may end up with just two) but i cannot figure out how to cut the last two sides if you do not have a square reference. Please help as i will end up planing it all by hand otherwise and i only get two hours a week. Any advice will be utilised with thanks.
PowerTool
24 Jul 2005
Darlington
You could keep the tapered offcuts and temporarily fasten them back onto the legs,which would give you a square edge again.
But open to better suggestions :D
Andrew
jasonB
26 Nov 2004
Surrey
Power tools method is the usual way of doing it. You could also make up a sledge type jig that holds the leg at each end and at an angle to the bandsaw fence, rotate the leg 90 degrees and pass through the saw again.
Most table legs are only tapered on the two inside surfaces otherwise the table can look topheavy.
Jason
Gill
3 Sep 2003
Lincs
Would it be worthwhile making a dedicated jig just for the one project? I agree that PowerTool's suggestion is probably the most practical way to do the job.
Gill
Garrett in Victoria BC CA
4 Dec 2005
Canada
Fine Woodworking had this tapering jig in a recent issue. I made it and consider it to be one of the best and safest jigs I've ever made and used. I'm surprised how often I reach for it. Better still, it will do 4-sided tapers easily.
If you go to http://www.taunton.com/finewoodworking/pages/wvt115.asp, you can watch a video of it in action.
Cheers, Garrett
Newbie_Neil
27 Jul 2003
Nottingham, England
The tapering jig that Garrett uses has a locating pin so that when you come to the final cut the pin gives you that extra support.
This is in addition to the holding pressure exerted at the other end of the jig.
Neil
PS Garrett, yours looks even better than the original.
Corset
5 Mar 2005
Nottingham
Thankyou for your ideas i think i will build a sledge and probably just two sides but that jig does look tempting.
With regards to 7.5cm square i had a bit of an over engineering moment. Cutting the planks into strips was a nightmare. But at least it won;t snap easily> :D
RogerS
20 Feb 2004
In the eternally wet North
When you make your sled(ge) make sure that you put some stop blocks otherwise there is the risk that your leg will move as it goes under the thicknesser...sorry if Grandma's suckin' eggs :lol:
