Calling all table saw fans - I need some teaching, please.
I got a 2nd hand table saw to:
* make cutting sheet material quicker
* get super clean cuts that don't need further finishing
* cut to final dimensions on first pass
* achieve dead-square (or precisely angled) components such as cabinet sides & doors with ease.
I mostly use 8x4 sheets of mdf, veneered mdf or ply.
I used to use a straight edge and ciruclar saw, then I upgraded to a plunge/track saw. But I'm tired of sorting out support under the workpiece, repeating measurements even for identical components, and moving the track half way through the cut particularly on the 8' dimension. I always ended up with teeth marks or burn
because I found it difficult to keep a super-steady pace and pressure on long pieces.
But after doing my first test cut on the table saw yesterday, I quickly found 3 big questions:
1. Are full sheets just too unweildy for a table saw - so do you have to cut them down first e.g. with the circular saw?
2. How do you handle large pieces (e.g. 2000x700 for the side of a wardrobe) without the long edge wandering away from the fence even by a mm or two for a second?
3. My fence can be set a maximum of about 200mm from the blade - so what's the workflow for cutting that 2000x700 piece. Do I have to cut to rough dimensions with the track saw, say 2010x710, and then set the table saw fence 5mm from the blade and cut the piece to final size?
I want to end up with great cuts, but I want to do it as efficiently as possible. Advice much appreciated.
