Table saw problems
mailee
26 Jun 2005
grimsby Humberside
I had just started work on a set of french doors today when my table saw rise and fall gave up the ghost! :eek: As I tried to raise the blade it went tight and then dropped! Just what I needed in the middle of a job! I ended up having to dismantle the motor to get at the gear but found that the wheel running in the worm drive had lost most of it's teeth. :roll: I managed to effect a repair by rotating the wheel 180 degrees and use the better teeth on the opposite side. I did get it all back together and working and even managed to finish off the tennons I was cutting. :D does anyone know where I can get replacement parts for the SIP 12" table saw?
clk230
1 Jan 2010
essex
my 1st port of call would be to contact sip direct .
Dodge
15 Oct 2010
Shelfanger
SIP are pretty good at getting spares to you but if you have any probs give me a bell, I might be able to help :wink: :wink:
Chems
23 Apr 2008
A Wood Haven
I had a delivery guy come to my place once and he saw the sip saw and said "oh SIP 01332 I used to work for SIP those things never break" well this thread has put paid to the confidence I did feel!
I've found SIP to be quite good on the services and repairs front.
Karl
2 Jul 2007
Workshop
In fairness I reckon Alan uses his SIP 10x more than most on here - a true "trade" rated user.
Glad it's getting sorted for you Alan.
Karl
mailee
26 Jun 2005
grimsby Humberside
You are spot on there Karl, I do use it one hell of a lot and it was second hand when I bought it so I can't complain. I have been very happy with the saw and it has done everything I ever wanted and more. :D Them Motors are damn heavy though! :shock:
