Hi all,
I recently bought a new Itech 01332 table saw, having read good things about this and the SIP & Axminster variants. Obviously I picked the Itech as it was the cheapest .
The top comes preassembled to the upper part of the cabinet and face-down on the pallet, so the thing was pretty much fully assembled before I turned it over and took off the protective plastic. Putting a 24" straight edge on the top I found it rocked noticeably in a couple of places, and showed light in a couple more- not encouraging. So I got the feeler gauges out and found a maximum deviation of between .25mm and .3mm- ie. the .3mm gauge just about interferes at the lowest point.
I found some posts on US forums and the general consensus is that a tolerance of .01"=.254mm over the entire surface is normal. I'm getting that just over my 24" straight edge, so the total deviation is almost certainly greater than this. Now I've added the extension tables, both of which are much flatter than the main table, and the left one particularly really shows up the distortion; however I set it there is a very noticeable step between the two at one point or other which is pretty annoying.
Now I'm a realist, I know it's a sub-£1000 Chinese saw and not a granite reference slab. I also know I'm working wood, which moves day to day, but I do find this all quite irritating from a brand new machine. The options as I see it are:
- Just live with it
- Try to send it back
- Sell it and buy something better
- Try to level the table myself by hand
Do any of you have this issue with your Sip/Axi/Itech saws? What would you do? Sorry for the long post.
Jona
- Just live with it
Jona
