Recently purchased the above saw as a full refurbishment. New 240v motor, DOL, belts, paint job etc. It arrived with zero dust on it and there was little to do to it. Only attach the extension bars and sliding carriage. I had to attach a hard wood piece to the fence, only had had 90x22 oak so used that. All good.
I went to cut some plywood for French cleats and cranked the blade over to 45 really smooth, booth up and down and tilt the blade would only go over to 45 on full rise as I think it hits the internal side of the body. Then I noticed the blade kicked out of square? Used it any way as I needed to. Material had about a 10mm gap to the rear of the Fence, can this be adjusted?
Really need to sort dust extraction out too. Soon piles up on the floor!
James
James
