startrite Mercury
JWD
4 Mar 2017
Lancashire
Hi All,
just seen a startrite mercury for sale, worn condition and rust on the shaft but apparently working well and looks very cool! has anyone got one of these or an idea of how much i should be prepared to pay?
nice one
Joe
Depends what worn really. rust cleans easily with scotchbrite and elbow grease
Bench mounted up to 150 floor up to 200 perhaps
If it has a gearbox (as well as belt changing) add £100
Ian
I've got one the same as that. Great machine. Used for metal and wood. (Got mine for £50 about 10 years ago - poor ebay listing).
I'd pay £200 to replace mine if I had to.
Make sure there is negligible runout at the chuck. On these drills the chuck taper is an integral part of the shaft and if bent is very very difficult to cure. If it is bent, then walk away.
Thats cool! i'm going to have to go for it i think! update from the bloke selling:
Says its been in a container for a couple years, rattles a bit but he thinks its one of the parts at the back. Also apparently not been serviced for a while so 'yes it will need fettling'
Still sound worth it? never serviced a drill press before!
Thanks for the replies everyone!
Joe
Joe
They are very simple they are a bit nuts and bolts and pressed steel on a startrite a fobco is much better made
if it rattling at the back it could be pressed steel guard, motor pulley loose, belt loose ,
at the front it could be pulley loose or quill needs greasing
the table clamp /lock arrangement isnt very good it clamps hard and true but its difficult to move it a gnats when you need to
fobco slightly better arrangement but still no fine adjust
the larger fobco 7/8 10/8 drill are far better but also treble the weight
ian
The rattling is normally the cover over the pulleys, when I had one of these drills, it always rattled.
The main thing to check is the quil.
Extend the quil as far as possible and give it a good tug in all directions and feel for any movement.
Next place something you know is round and true in the chuck and using if possible a clock check when running that it has very little runout. Some run out is inevitable. If there is excessive run out, the drill is only good for spare parts. Machine Spares sometimes have a quil when they have an old drill they are breaking up, but it will cost about the same as the drill!
When extending the quil, feel for any flat spots, or difficulty winding it down / up. If they have been abused the cog that moves us up and down gets badly worn. You can get another shaft and cog made for about £200!!
I'd want the original on off switch, and for it to be good condition.
Take the belt off the motor and give the pulleys a good tug, your looking for excessive play. If either have any movement, walk away. It will cost more to fix than the drill.
Lastly, with an engineers square check that the table when clamped in serval positions is true to a long straight bit / rod you've placed in the chuck. Check at two places 90 degrees to each other each position of the table. If it's not true, walk away. Sometimes to remove rust the drill stem that the table attaches to gets sanded and is no longer true causing the table to lean. The table can be adjusted side to side on some models (only say that because it did on mine) but it can't be adjusted front to back.
Good luck
For safety i would chuck that switch and fit a dol starter or a NVR switch ...the original switch is just as bad as whats fitted
If your table isn't square its easy to fix actually. Only time consuming ...fitting ,checking and adjusting refitting checking
This is all very helpful gents thank-you!
Yeah if i do get it i'll certainly be modifying it a little - and probably putting a table over the cast iron one so i can adjust that to be perfectly square.
So quill and pulleys have to be dead solid ok - i guess if its not right and the bloke selling says i've already bought it ill just have to say it's not in viable working order? would that be justified?
thanks again
Joe
If the stem has been fettled affected the tables alignment, you cannot adjust it out except for the one location! Every time you move the table up or down the table will need truing back up.
