fluffflinger
First up I am aware that the sides of a plane don't need to be at a perfect right angle for shooting as it is the blade that needs to be at 90° to the sides. However I would like to bring the sides of my No7 square to the sole.
I have checked the plane and the material to be removed is pretty much uniform down the length of the plane side. It would appear that I need to remove a bulge about 10mm wide along the length of the plane where the side intersects with the sole.
I have files and a piece of granite upstand (1000mmx120mm) that I use for flattening but I'm not sure what is the best method?
My initial thought is to glue a piece of 80grit to the granite leaving 70mm of the granite exposed on which to run the side of the plane and then lap with the offending 10mm on the paper and the plane side running on the granite. So in effect the potential "depth of cut" of the 80grit would be it's own thickness. I could, if this is too much, add add tape to the plane side or granite plate to reduce the amount of material being removed and the angle of the cut.
If anybody understands what I'm talking about and has any advice it would be most welcome.
