Spirolux Ducting. Advice please
ScouseKev
29 Jun 2011
South Liverpool
Its about time my workshop was properly set up for extraction.
Looking at the forum it seems that Spirolux is recommended, BUT i cant find anywhere to buy it.
I have a Deft t/s, sedgwick 10x8 p/t, 9" belt/disc sander, Bobbin sander, 2 band saws and a router table.
The workshop is 10m x 4m and im currently just connecting machines as needed via 2 Record extractors and a 3hp Lyndhurst with fine filter.
Am i right in thinking that 100mm Spiral ducting is the way to go.?
Any advice would be appreciated. Thanks
cheers Kev
If you want to do it properly then you should use clipped steel ducting which will create less turbulence.
Here is a link for a company which supplies both.
http://www.ducting-online.co.uk/default.asp
This is my shop, the clipped stuff is more versatile and easier to change etc etc
I'm in the process of moving all my machinery due to getting a 4 sider, I can just un-clip and rearrange.
