markus":2zdzjwku said:what size router(hp) did you put in yours?? are routers up to the job for some of these larger cutters??
WiZeR":ozak7b08 said:Martin: How do you find the Triton for adjusting the height when in table mode... is it a 'dodle'?
FelderMan":2gb0u9nb said:I seem to be in disagreement mode tonight .
Spindle moulders can be inexpensive, there's quite a few used models on Ebay etc.
As for cutters the stock items are in fact as cheap or cheaper than router cutters, Spindle moulders imho cut much better giving better constant results and of course much quicker.
A 2hp machine hardly take up anymore room than a stand alone router table.
It all depends on what your planning on making.
Hope this helps
motownmartin":3naf6l0n said:FelderMan":3naf6l0n said:I seem to be in disagreement mode tonight .
Hope this helps
I must agree with you Felderman, the only thing is that a router table is much more versatile than a spindle moulder, for example how long would it take to make this?
All done on the router table in a few hours, including the dovetails.
FelderMan":vcuzfnak said:About an hour My spindle moulderis also a table router with powerfeed
Nice box by the way
dirtydeeds":2keiue2a said:felderman
the prices of the cutters for spindle moulders are cheaper than router cutters
but one of the main reasons my head says no to a spindle moulder is the cost of the cutter heads
they look to cost around £200 each and it loos like you need a good half dozen just to start with
is this correct
or will a single cutter head hold all the cutters (and the limiters)
