Some Issues with Power Tool Purchases - Advice Please
paulc
20 Aug 2003
Ireland
Hello,
Couple of problems with two online power tool purchases and hoping to get some feedback:
1.Bosch AL1860CV + 1600A002U5x2 Charger 2-18v-5Ah CoolPack Batteries
One of the batteries charge level indicator did not light at all when pressed (even though manual says they should) I thought perhaps it’s because its brand new - so charged for 1 hour - nothing - on closer inspection it looks used. (slight wear on base)Other battery and charger seem brand new.
Charger and batteries came in clear plastic bag with manuals - no box / case.
2. Bosch GST18V-LISN Jigsaw 18v BODY ONLY
This was simply in a bag with manual and a couple of blades - no protective box of any kind - Is this normal??
SDS ejector button for blade did not pop out blade - it releases it so it can be taken out - but only ‘popped’ / ejected onto workbench once in ten or so tries. Probably wouldn’t be concerned about this except for dodgy battery.
3. DEWALT DPN1850-XJ 15-55mm 18g Brad Nailer (bought online from another well known retailer)
No allen key in carry hook as there should be. Has this happened to anyone ?
Appeared to be fully sealed - although slight hole in plastic wrap at case handle - probably where someone picked it up. Also was a black cable tie around handle - I suppose to prevent tampering - is this normal.
Other wise it seems to work fine although after finding no allen key (and maybe the dead battery) I have found some slight scuff marks but nothing that shows real wear.
All advice / comments appreciated.
Bare tools I have bought in the past have at least come in a cardboard box, sometimes an unbranded cardboard box, but a box nonetheless - Bosch specifically in fact.
Bare tools not in the manufacturers box, or just in plastic bags are normally remanufactured or refurbished, should be a lot cheaper than new and you have to expect some scuffs and marks.
Mike
