silver steel
marcros
11 Feb 2011
Leeds
I bought a piece of 10mm silver steel round bar from ebay. I have just measured it and it is 9.4mm. is this right, I thought it was ground to 10mm rather than starting at 10mm.
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
Have they sent you 3/8” by mistake? I always get my stuff from Ground Flat Stock (GFS) and it’s always ground to exactly what is stated.
marcros
11 Feb 2011
Leeds
I wondered that, but even that should be 9.5mm. I have sent them a message (not as in The Godfather) so will see what they say.
AES
18 Feb 2011
Switzerland, near Basel
AFAIK marcros, a piece of 10 mm dia silver steel should be EXACTLY 10 mm (to within a VERY tight tolerance). I'm not 100% sure mind, but 99%, and certainly any silver steel I've bought (both from the model engineering suppliers and from a local steel stock holder - where I had to buy 5 Metres length!!!) has always been spot on the quoted diameter. So I THINK something's gone wrong at your supplier and would take/send it back if I were you.
Even buying just plain old MS bar at 10 mm dia will be much nearer 10 mm than your 9.4/10 mm SS.
Sideways
26 Dec 2017
United Kingdom
Silver steel bar is centreless ground.
It should be exactly 10.0mm
You are entitled to return or replacement.
MorrisWoodman12
11 May 2017
Deepest Sussex
I would expect the standard engineering tolerance for something like this to be +/_ 0.1mm. But 0.6mm! That's Ebay and Amazon for you. You have to be careful.
marcros
11 Feb 2011
Leeds
I hope it was an innocent mistake, it was an engineering supplies place on eBay rather than a chancer!
sunnybob
wysiwyg
11 Oct 2014
cyprus
The question has to be asked;
How accurate is your measuring stick? :oops:
Rorschach
Guest
6 Jan 2016
Devon
I wouldn't a bar to be exactly on size unless it came with specifications and tolerances. Of course 9.4mm is nowhere close to 10mm so something has gone wrong there.
redhunter350
17 May 2018
North Lancashire
Macros, I agree with Trevanion it seems you have been sent 3/8" [9.525mm]
Quality silver steel is sold in 13" or now 1m lengths and made to a tolerance of +/- 0.00025" this has been the norm for the last 60 years, it was pretty much PS Stubbs who were the major supplier/producer in Britain but now there are several. I use Coventry Grinders or Ground Flat Stock thus ensuring a known quality product.
marcros
11 Feb 2011
Leeds
at least the length is right!
I have chased them, if not PayPal can deal with it. If I hadn't already drilled the hole, I wouldn't really care but I need a close fit.
marcros
11 Feb 2011
Leeds
eBay seller refunded when I sent it back. I bought a length from Cromwell in the end, which was cheaper after all that!
