PerranOak":aik0ig2y said:I wonder, when you've used a plane on a shooting board with the blade sticking out a long way then pull it back, doesn't it leave a gap that would cause break-out?
As I said earlier, the setting for a shooter is as you would have it for normal bench planing, which is generally finly set, smallish mouth and very sharp...it's not difficult :wink: - Robwoodbloke":2uehokva said:The plane setting for use on a shute is as you would have it normally set up for bench planing, it's not that different 'cept that the plane's on it's side - Rob
Digit":1bz7s39l said:My method PO is a sacrificial face on the stop block, if you haven't taken that route and can now cut the damaged face away you should then be able to reface it now and in the future.
Digit":38t8g6m6 said:Basically yes PO, but if the feather on the edge is small normally you can simply live with it. Alternatively plane the edge that rested against the fence/stop and remove any breakout that way.
I wonder ... if I shunted the facing piece on my stop block (it has a hardwood face) out a bit, that might help?
Digit":3vmrf7uu said:That should do it, but remember PO, the edge always wears in the long term, which is why I use a sacrificial face and replace it as needed.
Pete Hughes":2v4evk84 said:... wondering the exact same thing, that the plane must shave the edge off?
woodbloke":2lk6b9t1 said:PO - t'would be far easier if someone could show you how a well set up shooter works...shame Alf has departed as she was in your neck of the woods - Rob
