linkshouse
I thought it best to start a new thread for this - hope no-one minds.
This may well end up being quite a long WIP as I hope to show as much detail as possible. My initial work is at the computer and it is worth spending quite a bit of time here as any corrections/adjustments here are much easier than once you're in the workshop cutting wood.
I have been working in Photoshop laying down paths over the photo using the pen tool.
I find it is easier to reduce the opacity of the photo that I am working on first so that the paths are easier to see.
Here is a screenshot of the paths overlaid on the photo, they are bit hard to see here in black and as we are looking at the actual paths they are only one pixel wide.
The pen tool can take a bit of getting used to but it is worth the effort. To start with I just lay down the paths fairly roughly without trying too hard to get them right. Then I go over the paths using the direct selection tool (white arrow) to select and correct the individual points. The best tip that I can give here is to try and manage with as few path points as possible as it will make your curves smoother and ultimately easier to cut once you get to the scroll saw.
Next I turned off the photo layer and zoomed right in so that I could go over the paths in detail tidying up any ends that didn't meet each other properly.
After the paths were all tidied up I created a new layer above the photo layer and filled the background with white.
Then I select the brush tool and set the brush to a simple round brush with a thickness of 3 pixels and hardness set to 100%. I prefer my patterns in red so I set the pen colour to red.
Next, make sure that your new layer is selected in the layer palette (I rename my layers to keep track of them).
In the Paths palette make sure that your path layer is selected and then click on Stroke to stroke your layer with the red 3px brush.
Deselect the path in the Paths palette then change back to the the Layers palette and you should have a cut path as below.
This is where I am up to so far.
Next job is to number the pieces, add grain direction lines and decide what shade each piece will be.
This all seems a lot of work for a pattern that is for personal use but as I mentioned at the start of this post a bit of extra work here can make life much easier and less prone to mistakes when you get into the workshop.
Sorry this has been so long and I hope that it is of interest.
Regards
Phill
Regards
Phill
