Diamond ones last many times better than ordinary ones. That's good for cost, battery life, and the work looks better as screwheads get less damage.
I was put onto them 30 years ago by a kitchen maker/fitter, when they were uncommon and a lot more expensive than they are now (he also had the first battery powered screwdrivers I ever saw). I bought two back then and actually found one in a toolbox tray recently. Of course those are worn out, but they lasted and lasted.
Now I use Wera ones as they seem to have taken market dominance. I keep one Phillips in the set, just in case, but mainly use #2 Pozi. And I'd never purposefully go back to ordinary bits.
Bear in mind that the Pozi shape was designed to cam-out (supposedly once the correct torque was reached). Phillips do drive better, but in my experience both screwheads and driver damage more easily. The only difficulty I now have is keeping track of individual bits, with a view to chucking them out.
I don't think they wear much, but the surface of the diamond drivers gets clogged with metal (zinc plating?) from the screwheads and after a while they don't work as well. I discovered some conc. hydrochloric acid in the back of the garage yesterday (don't ask), so I might have a go at dip-cleaning some old ones, to see if they can be rejuvenated.
Try one diamond bit, ideally in a bit holder (they do seem to work better that way). I'd be amazed if you go back to ordinary ones afterwards.
E.
PS:i have also found they're great for removing old damaged screws you might encounter, say in the sort of old house we have that's been patched up a lot over the years.
