Router table top cover
Gadjet
10 Jul 2019
Cheshire
Hi,
I'm just putting together a router table and I was wondering if the MDF I'm using is good enough or is there some hard-wearing veneer that can be bonded to the top?
If so, where's a good place to buy it from?
One of the members here made a router table using a piece of laminated kitchen top from one of the hardware stores.
My proof of concept phase so far :)
Hi,
Kitchen worktop is a good posibility but I would look seriously at 'Tufnol' sheet which is available from 1mm to 50mm thick which you could use as a 'surface' ( 1, 2 3mm thick) or a solid (12, 15, 20 . . . mm) - - - available from directplastics.co.uk along with many other hard-wearing industrial plastics such as HDPE, PE500, PEEK and others - any of which would be vastly superior to MDF (in any form).
I would imagine it makes a nice slippery surface to make passing wood through the cutter easy. I think the price is prohibitive for using it as a solid top, 25mm @ 600mm square is £477 inc vat and at 30mm £534 inc so using it just as a cover or surface is more cost effective, those prices are in the same ball park as buying a ready made, ready to use router table / router table top. Buying 6mm same size as a cover is £115.
Another product to look at are the composite panels used in vehicle body construction, things like the delivery vehicles used by the supermarkets and other vehicles with a specialised purpose.
Pray tell what's the roller pressure finger alternative thingybob?
I bought it from Banggood, it's rollers only roll one way so in therory stops the wood from backfeeding (not the reason I bought them) also the wheels are angled in towards the fence pulling the wood against the fence as it goes through, I made an error though as I thought the price was for two but it was only for one, my fault for not reading the details properly :-( anyway it's a really good quality bit of kit.
I was looking at some 1mm tufnol sheets as a way forward.
Most router tables use a plate to fix the router to, so most ware will be on the plate not the table as the finger boards will be around the cutter
Without quoting or referencing my post I wasn't sure that you were talking about Tufnol @Spectric :unsure: The figures you quote do confirm that though.
I agree that Whale brand Tufnol is not a cheap option but Kite Brand at 3mm thick 600 Sq is <£32 - Personally I only buy Whale but then I don't use that much, never bought thicker than 12mm.
So how does this material machine, cutting and routing wise ? Also how do you fix it to your underlying board, normaly I would have thought they were put on under pressure .
Superbly! - It's essentially a Phenolic Resin impregnated material, Whale is Cotton, Kite is Paper (hence the lower cost) full details Tufnol
I use it for Gears - mostly clock gears but also Myford 20DP Change gears - as well as Clock plates. It is utterly 'stable' over a wide temperature range - I've never had any issue with expansion/contraction.
Drilling, threading, milling, sawing - absolutely no problem, similar to brass, better than Alum.
I've never needed to make up a composite but suspect that if I needed to it would be by screwing together. Should I consider glue for a 1 > 3mm thick sheet, I would try something like EvoStick Contact. - I have fabricated some 'parts' (small) using CA without issue.
I first came across it in the late 50's during my apprenticeship.
