Router Bushing
Echo-Star
13 Dec 2018
Leven
Hi Guys, Girls
I've recently purchased a woodpecker shelf pin template for a project that I'm doing. Unfortunately the jig arrived without a guide bushing of the appropriate size, and try as I might I cannot find a 3/8" guide bushing anywhere. I've come across sets that include the size that I require for now, however reading the reviews on these items are not good to say the least.
Can anyone advise me on this
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
You need to find a supplier of 'merkin bushes as they will be imperial. Woodpecker stockists should have them for the normal screw in guide bush style but depends on your router fitting too.
If you have access to an engineering lathe then its an easy turning job to make your own.
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
Hi Guys, Girls
I assume you're talking about the US (Porter Cable) style ones that attach with a threaded ring? You can get imperial guide bushes from Trend (and I think Axminster) but you'd need to get the appropriate base/adapter.
If you bought the template from Woodworkers Workshop, the boss (Peter Sefton) is often to be seen on this forum but why not email him for advice?
Echo-Star
13 Dec 2018
Leven
Thanks for your reply woody
Yes I've seen those KATSU sets online, those are the ones who had bad reviews, tried AXI, Rutlands and looked at trend, was hoping not to fork out and buy a new base plate also. I have 3# routers, so I'll check the model numbers and hopefully get/find one that is compatible, as Its not an addition that I'd use a lot of at the moment, as in buying a set and base plate that is.
Thanks again
