Deejay":10tmg3w1 said:Afternoon all
Which lathe is it?
Dave
Keithie":2ryswi49 said:The advice they gave was twofold :
1. Start at low speed and only move up slowly ... the speed control doesmt like the loading of having to power up fast (obviously, again, I'm paraphrasing with my interpretation...but I got the sense of ..just be a bit careful when you turn the speed up ..dont whack it up from off straight to max etc)
2. Give the motor a chance to cool down for say 20mins or so every hour or two. (at low speed obviously there are going to need to be energy losses in the form, mostly, of heat. given how we can all, I guess, quite happily turn for a few hours, that might risk a heat build up etc)
themackay":2wj1at7w said:Has anyone one got a link to suitable replacement pots they have used
Deejay":xpjbyeim said:They both have linear tracks.
andygc":2676idpl said:It's not in a dusty environment. It's inside a metal case with a sealing gasket which is not intended to be opened in normal use.
