Jacob
New Luddism. Awake and resist!
If you adjust your plane to take a typical cut, then detach your blade , cap iron and frog (without upsetting the adjustment) and then re-attach the blade and cap iron to the frog in their working position, you will see that a 2 to 4 mm band of the back is visible, before you reach the bevel. This part of the back will bear on the back of the mouth if there is zero adjustment on the frog. Ideally a gnats less than zero, for a tight fit.Racers":2nqbva2p said:Hi, Jacob
So you don't have a bevel on your blades?
That is the only way you could get more support to the back of the blade.
Try it and see for yourself - save me the bother of photographing it.
This also suggests that the larger the bevel angle the better as this will put more blade on to the back of the mouth, but there has to be clearance under the bevel itself.
