Quick release vice problems
graduate_owner
5 Aug 2012
Llandeilo
Hi everyone,
I have two quick release wood vices, a Record and a Woden. They both suffer from the same issue, which is they slip their threads when tightened. I have pulled them loose and tried to tighten the springs, but I can't get them tight enough to keep the half nuts from slipping. At the moment I wedge some timber underneath the mechanism to keep the half nuts tight, but it's not an elegant solution.
Anyone have any ideas?
K
Have you got any photos of the thread and position of the lifting mechanism - it sounds like the mechanism might not be in full contact with the thread (not much to go wrong on these)
It may be a worn bar. I have the same problem and am due to buy a length of flat bar and try that. I too have wedge...! Best wishes.
I suspect the spring that keeps the bar up may have lost some tension over time. Adjusting the tension might help - from memory its a bit fiddly ;)
Edit: oops, looks like you've tried that- soz
Sent from my GT-I9300
Check the thread on the bar and in the nut, these vices do last a LONG time but they do wear out. So if that's the case. Save yourself a lot of trouble and buy another one off ebay, they aren't that expencive.
