I have 2 questions if I may please:
The first relates to Dust extraction on the 502 and 502E
I have seen a 502E in a shop and it has 2 No 4" DE points.
Do I need to have both connected?
I only have a photo of the front-left of the 502 and only one DE point visible: does it have 2 DE points also?
What are the main differences between the 502 and the 502E
The ones I have been able to glean thus far are as follows:
[width and depth of cut not a concern, neither are the educational safety features associated with the E]
Item...........502............502E
Max Blade:. 25mm vs 35mm
Weight:.......240kg vs 200kg
Guides:.......metal vs ceramic
Motor:.........2hp vs 2.5hp
Thank you
Thank you
