kirkpoore1
jimi43":mesnqbfz said:These are the answers I usually get.......and yet I remain confused.
I have a sliding mitre saw which I use for cross cutting. It has stops...clamps to hold against the fence and surface and will cut pretty wide panels and all feasible lengths/depths of stock. The only thing it won't cut is panels wider than the reach...but I use the tablesaw for that anyway.
So...again...my question is, why use an inherently dangerous piece of gear that is known to be lethal if not used correctly as opposed to a fairly safe sliding mitre...which at least chucks chips out of the back?
I take all the points about safe practice...but surely that applies to ALL powertools?
Jim
Lethal? No. Dangerous? If, as I said, not used with caution.
Rigidity, durability, ability to tune it up if it isn't quite right. (Though the latter may be possible on better CMS/SCMS, I don't know.) I'm not sure what you mean about the chips, since mine sends them out the back and into the dust chute I've added. It's got an induction motor, vs the universal motor found on many (most? all?) CMS/SCMS. I think some SCMS can be set to cut only partway through a board, but I've never seen one. I do tenon shoulders and dadoes frequently on my RAS. I also think it's reasonable to say that most RAS's will crosscut more than CMS's and most SCMS's. That may not be a big consideration for most people, but I do use mine to cut sycamore 2x16's to length fairly frequently (it will do a 22" crosscut, but it's a relatively rare long-arm version.) If I need to break down sheet goods, I go to my circular saw with a clamped on fence.
A compound miter saw is certainly more portable and will do what's needed as a jobsite saw. And they will do just as well for many simple cuts, at least for a while. A good CMS will cost as much as a cheap RAS, so if that's all you need get the CMS. But if you need more, a good RAS will do more. I've used CMS's some, but I like the RAS much more.
Kirk
