Bit of a stupid question, but I just want to make sure of something before I talk about a problem I'm having with an old Record 52 1/2. When the vice is tightened shut, you are supposed to be able to squeeze the quick release lever and the vice loosens and then you can slide it open with the QR lever still pressed? #-o
It seems the quick release mechanism on my vice is not functioning properly. The QR lever sticks regularly when pressed and won't pop back down again. If I slide the vice jaws closed while pressing the QR lever and then tighten slightly with the handle, I cannot open it again with the quick release lever as it is remains jammed upwards. When I open the vice again with the handle, the QR lever pops back down again. Alternatively, if I close the vice completely with the handle and leave the QR lever down, I cannot open the vice again by trying to squeeze the QR lever as it is jammed solid.
I can slide the vice open and closed with the QR pretty smoothly when it is unjammed, but if I slide it to where the jaws are almost closed and let go, the lever stays pressed tight.
From examining the vice when being opened and closed, it seems the QR sliding bar lifts slightly when the vice is tightened closed. Maybe this is why it is sticking
I'm just wondering what the problem could be? Should I be taking it apart and examining?
