I'm trying to plane a reclaimed white oak and I'm coming across 2 major problems:
1) sometimes when I'm making a pass the plane gets stuck. It looks like it takes more material than it suppose to. If I continue pushing with more force i will damage the surface. How to avoid it and what to do when that happens?
2) creating a smooth surface seams to be random. Some areas look nice while the other have lots of small irregular holes 2-3mm deep. It looks really bad and I couldn't use this surface as a table top. I'm wondering is that my fault or there is something wrong with the timber (or both). The timber looks dry on the surface but when I cut it with a circular saw the waste has a dark brown colour. Perhaps it's not dry enough although if that's a reclaimed timber shouldn't it be dry before the first use?
Thank you
Thank you
