The Gent
Hello,
I have a Fox F22-568 and am having some technical problems, when pressing the on button the machine would appear to start working but then cut out after about a second before getting anywhere near to top speed. When pressing the one button afterwards absolutely nothing happened.
I tried replacing the fuse (13A) from another tool that I knew to be working fine, and the same thing happened again, the machine would start to work but then cut out after 1 second.
I put the fuse back in the known working item and this failed to work, so I isolated the fuse as being the problem. I tried this once again with the same result (3 fuses now gone).
The only question what is causing the fuse to blow, any advice on what to do next. I work for a large manufacturing company with electrical engineers that I could ask for some assistance. Any other words of wisdom would be gratefully received.
Regards,
(Planer Thicknesserless) Kevin
Regards,
