Planer/Thicknesser advice needed
woodyone
26 May 2008
Sussex
Quite soon i will be putting a small workshop together and am thinking of buying planer/thicknesser but they are bit out of my price range, so are thicknesser really nessesary for a small workshop because don't planers do the same thing as a thicknesser but just take off less material. If this is true i could save myself quite a bit of money by not buying a thicknesser and just getting a planer. But i'm a bit confused over this :? and dont know if im asking a stupid question :oops: so if anyone could help me out with this that would be great.
Woody.
Hi Woody,
A planer is used to produce one flat surface and a square edge on a board.
A thicknesser uses the flat surface produced by the planer as a reference and machines the other face parallel to it.
I have seen set ups where the timber has the first flat surface produced using a thicknesser, a sled is used and the timber has to be packed level on the sled. I think it is a lot of effort to use one if you are machining lots of large boards. For small stuff it would probably work OK.
Hi Woody
Planer/thicknessers both remove wood but the difference is in how they are used.
Planers (more correctly, surface planers (jointers in US)) are used to produce a flat surface on a face of the wood. The wood is passed over the cutter block and across the outfeed table which, being flat, will produce a flat surface on the wood. Once you have a flat reference surface you would turn the wood over and pass it through the thicknesser - because there is a constant dimension (whatever you set) between the thicknessing bed and the cutter and you have a flat (planed) face you will get timber with two parallel faces.
Brian
Thanks brian and dave
So tecnically to just remove waste material and to square the wood just having a planer should work. right?
Woody.
With out a thicknesser you will end up with 2 faces at right angles, and another 2 at right angles but the 2 sets of face wont be in sync with each other.
Watch the Woodwhisper (another annoying american) episode 6 he explains it all very well.
Hi Woody
Forget the Whisperer - it's degenerated into a series of long commercials.
Have a look at this video. The rest of the series is also worth looking at as well.
Brian
