goldeneyedmonkey
Hello folks,
I need a hinge similar to this one, or one that does the same job, but ideally in metal as opposed to Nylon.
http://www.icarusmodels.com/index.php?m ... cts_id=594
Basically I'm making a little balance bike for my daughter for Christmas (I'll post an an image if it's more help) and I'm getting brain-ache with the best way to attach the 'forks' to the 'frame' so that they pivot enough to turn the bike. I was going to make it out of wood, but I feel that it would end up fairly chunky compared to the size of the overall bike.
I've looked at the above hinge as it's simply drilling 2 holes that are on mating surfaces and then gluing into position. Everything else seems a ball-ache to install compared to this idea. But the ones linked to above are destined for model aircraft and probably a bit weak.
Any help is much appreciated.
Cheers all. _Dan
Cheers all. _Dan
