Photographic wonder
bugbear
16 Jul 2004
North Suffolk
Over the weekend, I wanted a way to hold a sheet of glass at 45 degrees, for a photographic lighting trick.
I needed to cut a slot of just the right thickness in a piece of wood, and at first couldn't think of a way to do it - no saw I own cuts a kerf thick enough, and widening a saw kerf is difficult.
(with a table saw one would probably just make two overlapping kerfs, but a hand saw won't do this).
The final solution was "obvious"; I used my tiny Ulmia 348 mitre saw to make TWO cuts, rather(!!) close together, and then simply snapped out the tiny remaining piece. A couple of trials got the slot width I wanted. The blade was narrow enough, stiff enough, and held in place accurately enough for this technique to work.
BugBear
Looks good BB, any good for makers marks?
bugbear":3pn81cbp said:
What an interesting thought - I haven't tried.
But I will. :D
This would seem a good test subject:
another-plane-blade-maker-id-request-t24023.html
BugBear
OK. The simple rig was set up (including a cheap s/h camera from eBay)), and I waited for dusk (other the ambient light messes things up).
Here is the conventional use of axial lighting, on a coin:
But following Pete's excellent suggestion I tried the worn mark on the plane blade.
Wowza.
BugBear
Definitely a success and much clearer than the earlier photos. I suspect it's a lot clearer than looking at the original iron!
So now we just need to track down Leadbeater and Scott ...
My guess is a fairly short-lived general tool dealer.
What a fascinating thread! Photographic excellence, tool history and tricky woodwork - what more could you want? (Don't answer that...)
My father was a commercial, industrial and architectural photographer. When I was a nipper, I saw him set up camera and lighting to photograph documents, paintings and similar on many occasions (camera dead square to centre of subject, two diffuse lights equidistant from camera and equidistant from subject, all checked with a tape measure) but I've never seen the axial lighting technique before. Thanks for that, BB.
You're describing class "copy stand" technique; you can get rigs that physically (and permanently) embody the important features you describe;
BugBear
Interesting. Must try this for makers' marks on woodwind musical instruments. These have the extra problem that the surface is usually cylindrical. I have got best results in the past by grazing incidence light but haven't tried axial (other than a ring LED, which was not outstanding).
Keith
