duncanh
I've been using a Bosch electric chainsaw for the last few years and it's coped pretty well with what I've used it for. It struggled a little when ripping along the length of logs (ie. with the log led flat and the chain running along it's longest length). I was using it yesterday and had been going for about an 30 minutes (including stops to reposition logs) when the motor cut out just after I pressed the trigger. It started for about a second and then just stopped.
The fuse is ok, the plug socket is ok, there was no smell of burning from the motor, the chain is well oiled and I can see nothing wrong with the machine. Unfortunately it's out of guarantee so I either try to get it fixed or invest in a new one.
A petrol one would be useful on the odd occasion that I need one but most of the time the saw sits in storage. I know you can now get fuel that apparently lasts for year in the machine or in the can. The only downsides I can see of petrol are the cost (my electric was 1900W and an equivalent petrol would be over £200) and the noise (the majority of my cutting will be in the garden and I don't want to annoy the neighbours).
I've used Stihls whilst out with the local wildlife trust and got on well with them. Never used a Husqvarna. I know there are other brands but these 2 are usually the ones that get most discussion. Spares for them are easy to find as well and there's a dealer for each within 15 miles of home.
Any suggestions?
I should add that I've got my cross cutting ticket and all safety gear.
Duncan
Any suggestions?
Duncan
