Quantcast
Outdoor Plant Stand
custard
20 Aug 2008
Hampshire
I need to make a quick job for the house, a plant stand that rests against a wall. It will look something like this.
Here's my question. How would you prevent the feet from rotting? It will sit on flagstones rather than soil, so I was thinking of a stainless steel screw in each foot to lift it above the moisture, but does anyone have any better ideas?
Mrs C
3 Jan 2016
United kingdom
Masonry paint was suggested to me for some thing similar which sits on grass. Too soon to know if it works, but the advice was on good authority!
Marineboy
11 Mar 2016
Northumberland
I'm not sure if the screw will be the complete solution. It will keep the foot of the upright off the flag but in my experience you will get as much water bouncing off the flag onto the wood as might be absorbed through the base.
Bm101
Lean into the Curve
19 Aug 2015
Herts.
Yeh but it won't be sitting in water. And air will circulate so it can dry. Tanalised timber treated every couple of years should be fine shouldn't it?
You sure you're up to the joinery for this Custard?!? It's a pretty involved undertaking.
:shock:
Callum
23 Oct 2018
East Yorkshire
I saw a video today on YouTube where someone painted the bottom of his fence posts with bitumin paint. Don’t know if you painted an inch or so up the leg of that would help?
doctor Bob
22 Jun 2011
Matching Green
I made outdoor benches, I put M8 stainless steel bolts in the bottom. not only stops them sitting in moisture but can be used to level them up.
Osvaldd
29 Sep 2018
NI
All my outdoor furniture has bolt feet. No sign of rot after 2 years yet.
Nelsun
22 Jun 2015
Shetland
Made some planters and used stainless bolts too. Figured the endgrain could do with "something" other than just paint and used pound-shop epoxy I had kicking around.
Phil Pascoe
29 Jan 2012
I soaked the legs of a garden bench in preservative, let them dry then stuck Flashband to the bottoms - we moved fifteen years later and there was no sign of rot.
Jamesc
8 Feb 2009
southampton, UK
+1 for stainless scews
Our garden regularly floods during the winter and we have woodend structures that are now 14 years old.
I was told (i think it was on here) that as long as the timber has a chance to dry out it will take the soakings, it seems to be working
James
custard
20 Aug 2008
Hampshire
Thank you all for your suggestions. Stainless steel screws/lag bolts it is.
Jamesc
8 Feb 2009
southampton, UK
To mind I worry about sealing the ends as any moisure that gets in will be trapped by the sealing.
James
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
Yup +1 for stainless screws/bolts (two on each foot) to allow air to circulate underneath.
IME all timber - tanalised/treated or not - which cannot dry out properly (ie by being in direct contact with the ground) will rot, the only question is when.
Painting impermeable stuff on the bottom will trap moisture and accelerate rot.
Cheers, W2S
MattyT
29 Mar 2019
Sheffield
Hi,
My outdoor furniture has bolted feet and prevents rotting because of the air flow.
I'd bore 2 holes into the bottom of each leg of the plant stand and then use a hammer to tap a T-nut into each hole such as these: https://www.accu.co.uk/692-tee-t-nuts
Then thread a hex-head machine bolt into each T-nut. You can then add a hex nut which tightens up against the t nut to keep the adjustment on the bolt.
Sgian Dubh
12 Oct 2004
UK
custard":2wsmew9z said:
Here's my question. How would you prevent the feet from rotting? It will sit on flagstones rather than soil, so I was thinking of a stainless steel screw in each foot to lift it above the moisture, but does anyone have any better ideas? Thanks
I'd just use European oak, or the slightly less durable American white oak, and not bother with any feet or protective treatments. Both are classed as durable and will give 20 - 25 years life if in contact with soil. Maybe the cost of the material is a consideration(?), and oak is relatively expensive, so maybe that's why you're asking. Slainte.
doctor Bob
22 Jun 2011
Matching Green
May well last but will look horrendous if it sits in water or moisture. May well grey but the part wicking water will just go black.
